T Tijani_1 Commendable Jul 10, 2016 2 0 1,510 Jun 23, 2018 #1 Aspire ei 531 Bluetooth not working solution
Solution electro_neanderthal Jun 23, 2018 First: Check drivers/install latest. Easiest if bluetooth is broken: Get a USB Bluetooth dongle. Most complete repair if broken: Replace the current Wifi/Bluetooth card with a new Wifi/Bluetooth card. How to: https://www.ifixit.com/Guide/Acer+Aspire+E1-531+Wi-Fi+Wireless+Card+Replacement/63917 The replacement part (I think - use the model number to see if you can use Google to find a better/less sketchy deal): https://www.ebay.ca/itm/Acer-Aspire-ES1-531-N15W4-ES1-512-WiFi-BlueTooth-Combo-Card-Atheros-QCWB335/132277571381?hash=item1ecc5b8f35:g:ZqoAAOSwg0FZfIi1 Hopefully that helps, good luck.
Lutfij Titan Moderator Oct 7, 2009 59,828 6,378 178,440 Jun 23, 2018 #2 If you haven't install drivers for it. You can find them here or here. Upvote 0 Downvote
electro_neanderthal Respectable Jan 22, 2018 450 2 1,965 Jun 23, 2018 Solution #3 First: Check drivers/install latest. Easiest if bluetooth is broken: Get a USB Bluetooth dongle. Most complete repair if broken: Replace the current Wifi/Bluetooth card with a new Wifi/Bluetooth card. How to: https://www.ifixit.com/Guide/Acer+Aspire+E1-531+Wi-Fi+Wireless+Card+Replacement/63917 The replacement part (I think - use the model number to see if you can use Google to find a better/less sketchy deal): https://www.ebay.ca/itm/Acer-Aspire-ES1-531-N15W4-ES1-512-WiFi-BlueTooth-Combo-Card-Atheros-QCWB335/132277571381?hash=item1ecc5b8f35:g:ZqoAAOSwg0FZfIi1 Hopefully that helps, good luck. Upvote 0 Downvote Solution
