I need hard drive controller card
zuhair mohammed
43
hi guys,I got hard drive HP wide Ultra320 ,80-pin SCSI “SCA-3” , I want to use it on my pc, the problem is the connector, it's SCA-3/ 80 pin, I need to find a way to connect it to my MOBO ,I didn't fined any kind of cable to transfer from SCA-3/ 80 pin to SATA II ,may be I will need for cheap or used controller card PCI with ribbon cable and I don't know how to find it ,any Suggestions guys thank you.
thank you for the quick responding some of the cards got alot of pin, does that work with the pci? and where can I find the ribbon cable connect SCA-3/ 80 pin to the hard drive with the controller? thank you.
most of the cards that I found were 68 pin or less maybe 50 pins or so,I didn't find the kind of the connector that I have in my hard drive,I wish that I can sent pic to show you what I mean,and I didn't find the cable that can connect to the controller card ,the only 80 pins that I found is ID ribbon cable and that kind of connector doesn't matched with my hard drive connector
http://www.public.asu.edu/~kxglw/scsi/scsi-pictures.html
scsi-pictures.html
New SCA 80-pin
yeah you're right I saw that when I was searching on line ,tha
t's 80 pins ,BUT, different kind of connector, the connector is not the only problem,the other problem is the controller card ,it has to be 80 pin ,so now I need to find a controller card with 80 pins and cable with the same connector
https://en.wikipedia.org/wiki/SCSI_connector
Drive caddies
SCA 80 pin Connector , or
SCA-2 connector on Fujitsu MAP3735NC
these two pics show you my hard drive kind of connector
