i ve got an 8800gts 512
until 3 weeks from now it was working perfectly fine when all the sudden it started to crash in games ... things went worse and worse until now it hardly even runs at all...
artifacts at windows startup screen looks like if bunch of lines were moved horizontally 2 inches to the right ... !!
when system FINALLY starts up ( if it starts up) i get those weird looking small dots all over screen, refreshing the screen would make that go away for a while, then at some point it would look like the black and white dots that u get in an old TV with screwed up aerial .. WTF seriously i bought that thing for 350 $$ ... this sucks !!
however .. sometimes i would hardly make it into a game .. like FEAR , i test in minimum settings .. all ok , i tested in medium 800 x 600 resolution and all hell broke loose, , texture and lighting artifacts .. and after that the wholes system crashed, today its not even running at all
i noticed that it would relatively run ok ( much less artifacts in a playable sort of way ) when its heat is around 52 ... once it goes 55 or so it goes bananas
I could really use some advice of what i can do ( other then buying another one .. were going through some crisis stuff ), and what might be the wrong thing with it ....
i d really really appreciate the help
C2D E7400 2.8 ghz
Intel DG31PR motherboard
2 gb ddr2 800 mhz ram
500 gb
Crazy 8800gts 512
C2D E7400 2.8 ghz
500 gb
Crazy 8800gts 512
