i need help about my r9 fury x
omegadavid
37
i was tryin to put the fan on the case and i accidently used the wrong screws and damages like 2 or 3 lines of the heatsink of the watercooler. does it make huge differance i mean it just 4 spots or whateevr in otherwords i bent like 2 or 3 lines of the heatsink....
omegadavid
37
what i ment is the heat spreaderin the radiator of the cooling. i was tryin to fit it in my case but i forgot i had to use the screws that it comes with and i tried to use regular case fan screws and bent 2 or 3 heat spreader of the radiator not huge mark
omegadavid
37
where the o are is wher you put thre screws and where are the red x is where i broke
