O OfficialDanielLara Commendable Mar 18, 2016 1 0 1,510 Mar 18, 2016 #1 Hi, I need help with setting up a PC upstairs, my router is downstairs and I have been hitting walls left and right trying to set it up. I am tired of having to game in my living room 🙁.
Solution S S Swapnil kum Mar 18, 2016 If your router supports Wifi, you can get a Wifi adapter for your computer. Then you can take it wherever you want(in the Wifi range).
S Swapnil kum Commendable Mar 13, 2016 52 0 1,660 Mar 18, 2016 Solution #2 If your router supports Wifi, you can get a Wifi adapter for your computer. Then you can take it wherever you want(in the Wifi range). Upvote 0 Downvote Solution
