[SOLVED] I NEED HELP. Are these Components compatible/ work good together?
Xxfyrus
75
I am looking to build my own computer and want to know if the parts I picked out are worth it, compatible. I know I will regret building one because I have never done it before.
I am worried about wires and not being able to have it look clean. I am also worried about space and heating issues. I dont know what more I will need to purchase.
Note I will be purchasing some items from best buy because I can finance them. I already have a GTX 1080, so that is why I am not including a GPU. I also want a more powerful power supply than I need because I will be upgrading my gpu next year.
CPU:https://www.bestbuy.com/site/intel-...ghz-desktop-processor/6302021.p?skuId=6302021
Motherboard:https://www.bestbuy.com/site/asus-r...ard-with-led-lighting/6311237.p?skuId=6311237
RAM: https://www.bestbuy.com/site/corsai...th-rgb-lighting-black/6256222.p?skuId=6256222
PSU: https://www.bestbuy.com/site/corsai...ar-power-supply-black/6229601.p?skuId=6229601
Case: https://www.newegg.com/fractal-desi...ase&cm_re=fractal_case-_-11-352-087-_-Product
CPU Fan cooler: https://www.newegg.com/p/N82E168356...ooler&cm_re=cpu_cooler-_-35-608-040-_-Product
SSD m.2 : https://www.newegg.com/samsung-970-...=m.2 ssd&cm_re=m.2_ssd-_-20-147-690-_-Product
SSD: https://www.newegg.com/samsung-860-evo-series-1tb/p/N82E16820147673
I would really appreciate as much help as I can get, including opinions.
They are compatible, but personally I would recommend these modifications (and from different sellers):
Your current link total cost (some prices might be a bit off): $1182.46
Or alternatively:
PCPartPicker Part List
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor ($363.99 @ B&H)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler ($59.95 @ Amazon)
Motherboard: MSI Z390-A PRO ATX LGA1151 Motherboard ($129.89 @ OutletPC)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3000 Memory ($79.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($99.99 @ B&H)
Video Card: MSI GeForce GTX 1080 8 GB Video Card...
Or alternatively:
Video Card: MSI GeForce GTX 1080 8 GB Video Card (Purchased For $0.00)
Case: Fractal Design Meshify C ATX Mid Tower Case ($94.99 @ Walmart)
Power Supply: SeaSonic FOCUS Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply ($89.90 @ Amazon)
Total: $918.70
Generated by PCPartPicker 2019-10-12 17:39 EDT-0400
  • No point in having the 2 SSDs, just get 1 660p for the value. Or you can just get 1 regular SATA SSD. No difference really.
  • Most parts are cheaper elsewhere
  • Motherboard you originally linked may be excessive for your needs, but I'm assuming.
  • 750W is even much more than most builds need, so 850W is likely more than you'll ever need upgrades and overclocking included.
Or alternatively:
Total: $918.70
The reason I choose best buy is because I cam finance and that would be the only way I could do this
I don't normally buy stuff from best buy, what does it mean to finance the parts rather than just buy them? Do you have a gift card, discount, or plan on down paying for the parts over time?
I have credit there. So I can by part by part and not pay full price right away, but pay it off no interest over 12 months. That's a huge plus to me. Some parts like the case, CPU cooler, and ssd I'll buy online though from newegg or something
I
Basically can buy everything I need there today , although I wouldn't because something's I will get cheaper elsewhere, and come home and build it while paying the parts off over 12 months
