I need help building a gaming rig!
iamcameronyoung
4
Hello. I am planning on building my first ever PC but don't have too terribly much to spend. I am limited to about $400 and don't know what parts to get. I want it to be a gaming rig though. Thanks in advance for the help!
this isn't the best, but it isn't the worst. no monitor included. didn't remember if you needed one but don't think I could have built something any cheaper that would be any good... ? did I miss anything ?...... the onboard" graphics should be good enough for what you listed. you can always add a graphics card later.
$390.00
dvd
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
case&PS
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144077
HD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131870
ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148559
cpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103943
opsys
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
