I need help building my PC
KvbUnited
7
So, im building my first gaming PC, and it will cost around €630.
Since this is the first PC I'm building, ever, I need opinions & info or this setup will actually work, and I want to know or it will be fast, VERY fast.
Here is the list of parts:
ASUS GTX750TI-OC-2GD5
AMD FX-8350 @ 4,0GHZ - 4,2GHZ
ASUS M5A97 Socket 2.0 MA3+
Sharkoon Vaya II Black
Seagate Barracuda 1TB 7200RPM
Sharkoon Shark Blades Blue Fan
Corsair 8GB DDR3
Aerocool AP-650 650W
I would look for a used GTX 670 for your graphics (a slightly older card based on the same GPU as the GTX 760, but slightly faster). You can find used and refurbished examples on ebay and Amazon for barely more than you're about to spend on your 750 Ti, and it will slaughter the 750 Ti in terms of performance, especially if you get one of the overclocked or dual fan versions.
I don't trust that case brand... Rather you get a Corsair 200D than this case. And the PSU... Again, the brand is expensive. Get a SeaSonic. And get the 8320 for $140 instead of paying more for a difference of 0.3Ghz. Get a CM Hyper 212 Evo with the money. And do try and get a GTX 760. That's for $50 more.
