I Need Help Choosing a Motherboard
A Random Shrub
28
I have seen all kinds of threads for my exact same question, but none of them are exactly what I need to know.
I plan to upgrade my AMD FX-8320 to an AMD FX-9590. My motherboard is a 970 chipset, and I know the 970 would do some funny stuff when the FX-9590 was put under load. Also, I am into the overclocking thing. My FX-8320 is at 4.5GHz, 1GHz more than stock speed. I would go further, but my liquid cooling isn't strong enough. I will be upgrading to a 280mm Radiator, which should more than solve my thermal problems.
I am looking for a motherboard in the $120 to $200 range. I picked out a few, but which one would be best for:
  • Overclocking with an FX-9590
    Running Two AMD Radeon R9 390 GPUs
    4 X 4GB DDR3 RAM (1333MHz)
Here are the boards I picked out (Gigabyte and MSi are my favorite brands, so if it ends up preference based, then there is my answer) Feel free to add your own.
MSI 990FXA-GD65V2 ATX AMD Motherboard
$129.99
ELIMINATED
ASUS M5A99X EVO R2.0 ATX AMD Motherboard with UEFI BIOS
$114.99
Also: Why is this one so cheap?
GIGABYTE GA-990FXA-UD5 R5 (rev. 1.0) ATX AMD Motherboard
$149.99
ASUS SABERTOOTH 990FX R2.0 ATX AMD Motherboard with UEFI BIOS
$179.99
ASUS ROG Crosshair V Formula-Z ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
$219.99
Also: This motherboard is out of my price range, but is reviewed great. I cannot find out what makes it better.
Thanks,
The one and only randomized shrub
Digi Power, 12 + 2 power phase IS A GREAT FIT FOR THE 9590.
Motherboard: ASRock 990FX Extreme9 ATX AM3+ Motherboard ($165.99 @ SuperBiiz)
Total: $165.99
Generated by PCPartPicker 2016-01-07 20:24 EST-0500
ASUS M5A99X EVO R2.0 ATX AMD Motherboard with UEFI BIOS is not compatible with 9590.
Your choices for the 9000 series:
Asrock 970 Performance
ASRock 990FX Extreme6
Asus Crosshair V Formula-Z
Asus M5A99FX PRO R2.0
Asus Sabertooth 990FX R2.0
Gigabyte GA-990FXA-UD3 R4.0\5.0
Gigabyte GA-990FXA-UD5
Gigabyte GA-990FXA-UD7
MSI...
Total: $165.99
MSI 990FXA-GD80V2
AMD.COM
Warning: This power draw of this CPU is almost twice that of the average CPU. Due to this, AMD recommends using at minimum a 850W to 1000W power supply. For cooling, AMD recommends using either either closed loop liquid cooling , h100i minimum or full system liquid cooling.
If thinking about putting out money for a 9590 and new mobo - going from an 8320 have a feeling you aren't going to be happyThe 9590 is a highly OCed 8350 (thus requireing 220 instead of 125 and thus a much higher rated PSU, Ive seen 8350s and 8370s OCed to the same as what the 9590 runs out (without needing the higher end PSU. I've got a 8370/Crosshair rig (in sig) and it doesn't begin to match up to a decent Intel rig - if going new, I'd go Intel, will be happier overall with a 4690K based build or the newwer 6600K
