I need help Choosing Peripherals.
Aiden Thursby
127
I need a Keyboard and Mouse like a Wireless Laser Mouse and a Wireless Keyboard so at nights I can sit back and use my PC in bed also It'd be fine if it had a USB adapter but the back of my PC is facing the wall away from me so I was wondering if USB would get a signal, and I do have 2 front USB ports but I want to use one for my headset and Mic I also would like to know if the MSI Z87M-G43 has a Headphone and Microphone jack at the back so I can plug in the mouse and keyboard USB's in the front rather than the back and if it helps the case I'm getting is a Core 1000.
I use a wireless mouse and i need the receiver on the front because the signal cant travel through the metal on my case to the back 😛
The logitech M510 is a nice basic wireless mouse. Its what im using right now
All motherboards should have a back audio and microphone jack.
In my opinion, wireless for gaming (assuming you do game) is just a terrible idea. It works, but is not ideal. I would suggest getting your normal wired keyboard/mouse and grab a Logitech K400. It's a wireless keyboard and mouse combo (all on the same board) that works rather well. I have one and use it for my HTPC. I love it because I don't have to have a seperate mouse/pad and don't have to worry about finding a surface for the mouse to work on.
