[SOLVED] I need help choosing PSU.
floorcleaner
66
5
4,545
Hello,
My PC specs
CPU: i5 10400f
Motherboard: MSI H410M Pro-VH
Ram: Crucial 2 x 8GB DDDR4 2666
SSD/HDD: 1 x Crucial MX 500 sata, 1x WD 570 1tb Nvme/1x Toshiba 7200 rpm 2TB.
GPU: Sapphire Pulse RX 6700 XT
CPU COOLER: GAMMAXX 400 V2 BLUE
ADDITIONAL FANS: 2x 120mm led fans in front and 1x 120mm non led rear
which one is best for me?
https://www.deepcool.com/products/P...0D-80-PLUS-Gold-Power-Supply/2021/12984.shtml
or
Are those the only two PSU's you have access to? Nothing from Corsair beyond the CV/VS series? Where are you located, what is your budget for your PSU purchase and what is your preferred site for purchase?
Hello, I am from India, and my budget is Rs 5,000–Rs 7,000. The sites I use are amazon https://www.amazon.in/Deepcool-PM650D-Certified-Supply-Gaming/dp/B09RV88ZQZ/ref=sr_1_2?crid=27M7RF37Q4HWJ&keywords=psu+650+watt+80+plus+gold&qid=1667895377&qu=eyJxc2MiOiIzLjg3IiwicXNhIjoiMy42NSIsInFzcCI6IjAuMDAifQ==&sprefix=psu+650+g,aps,452&sr=8-2&th=1 and this one https://deltapage.com/smps
Yes bronze or gold are efficiency levels, not immidiately signs of quality. The Adata is btw a gold effciency psu, but maybe not the shop you want to use, had to include it though, it's good quality.
Your welcome.🙂
I'll get the Adata gold one, and I live pretty close to Theit Depot, but until now, I was unaware of the shop. :)
Reactions: Vic 40
