I need help choosing some silent 140mm fans
lweston177
Hi there not to sure wether I am posting in the right place but here goes.
I have just brought a case and have support for 6 140mm fans and have put aerocool 140mm sharks in. These are plugged in to a fan power hub that came with the case so are running at full all the time and are way to loud . so I am looking for some silent 140mm fans that won't be too expensive
What would you recommend?
First off, 6 fans is way too many. Start with three:
top exhaust
front intake
rear exhaust
That will cool your system perfectly the same as 6 fans will. All you need is airflow, not air blowing all over the place.
