[SOLVED] I need help choosing the right config
Aug 15, 2021
hello , i found two kits to buy for like 400 dollars in my contry and thats my budget right now but i don't know which should i get for best gaming performance for me i mainly play world of warcraft and i wana play in 1080p with high graphic quality so help choose whats best for me guys .
build 1:
intel g5400
8gb ram 2400
msi gtx 1070ti gaming 8gb
CM psu 650w
gigabyte h310m
build 2:
ryzen 5 2600
16gb ram 3200
gtx 1650 gaming pro
CM psu 500msi b450m gaming plus
and thanks for advance guys .
dorsai
Build 2 is much more powerful on the memory & cpu while build 1 is much more powerful on the GPU. You really need to work out a better combination between the two because that intel G5400 is not at all good at gaming and I have serious doubts it will keep up with a 1070ti. If you have no choice but to choose one of the above I would go with #2 but realize both are compromised for gaming.
Reactions: blackwaar
build 1:
intel g5400
8gb ram 2400
CM psu 650w
gigabyte h310m
build 2:
ryzen 5 2600
16gb ram 3200
gtx 1650 gaming pro
Build 2 by a mile. Just make sure the memory is 2x8 not 1x16
dorsai
Aug 15, 2021
yes mate the problem is i have to choose between one of the build and thanks i guess ill go with build two and try to upgrade the gpu later when i got the chance for it . thanks for the help
Reactions: dorsai
build 1:
intel g5400
8gb ram 2400
CM psu 650w
gigabyte h310m
build 2:
ryzen 5 2600
16gb ram 3200
gtx 1650 gaming pro
On build #1 you have to upgrade cpu and ram.
On build #3 you have to upgrade GPU.
So - it really depends on cost of the upgrades.
Build #1 is easier and cheaper to upgrade than build #2. This is because gpu prices are rather crazy overpriced right now.
Build#1 upgrades
i5-8600 ~ €200
DDR4 3200mhz 16GB ~€70
Build #2 upgrades
GTX 1660 super ~€500
I'd choose build #1.
