[SOLVED] I need HELP, constant freezes
Jun 26, 2020
I don't know what to do, the past days I buy a PC by pieces with the next specs:
  • Ryzen 3900X - RTX 2070 SUPER
  • Corsair 3200mhz 16GB x 2 RAM
  • Asus Prime x570-Pro
  • NZXT c850 Gold plus modular PSU
  • WD_BLACK SN750 SSD (OS installed)
I start testing the PC and at first moment everything seemed to be going well but at 10min playing CSGO I start getting LOT OF FREEZES. Downloading MSI Afterburner I check that the frametime was literaly crazy going from 100ms to 10 ms 2 times every second.
I record a video o the freezes with FRAMETIME graphic and FPS on:
View: https://youtu.be/abfo33EzxEE
I try updating drivers, restoring OS, diferent monitos, HDMI, DP, 60hz, 144hz and I always happend the same around 10min of playing... Also i get DRIVER_POWER_STATE_FAILURE when the PC is shuting down. Any ideas? I'm desperate...
Thanks for your time
Are your "Power Options" set to High Performance?
Your problems could also be connected to the latest Windows 10 version 2004 update.
