I need help deciding between these three laptops.
AmmoScar
My budget is from $400-$500 and these three laptop fit my price range. I am buying this laptop to run games such as LoL, Dota 2, Minecraft, etc and edit videos using Sony Vegas Pro. (I am going to buy these laptops in stores)
1: HP - Pavilion 15.6" Laptop - 4GB Memory - 640GB Hard Drive - Sparkling Black $429.99
http://www.bestbuy.com/site/olspage.jsp?skuId=7015534&type=product&id=1218821792103#tab=overview
2: Samsung Series 3 NP350V5C-A01US 15.6" Laptop $499.99
http://www.staples.com/Samsung-Series-3-NP350V5C-A01US-156-Laptop/product_985038#pr-header-985038
3: HP Pavilion g7z Laptop, AMD Dual-Core A6-4400M 2.6 GHz
http://www.costco.com/HP-Pavilion-g7z-Laptop%2c-AMD-Dual-Core-A6-4400M-2.6-GHz.product.100015167.html
So, which one of these laptops should i get?
None. Never buy a laptop for gaming.
However, since you are intent on doing so, the HP Pavilion laptop from Best Buy would give you the best gaming performance out of the three. The lower screen resolution and the 7640G graphics class should provide you with a modest gaming experience.
-Wolf sends
I agree with Wolfshadw the HP from BestBuy with ATI discrete graphics will be best choice out of all three for casual games like Minecraft. I also would get the warranty it will be worth it. I owned 3 gaming laptops (Toshiba Qosmio, Azus G2) from 3 generations, they were top at the time I bought them and run great, each of them died after 2 years of heavy use 🙁 it all depends how much you will use your laptop, now I wish I had extended warranty.
