I need help determining what type of screwdriver I need for this screw head(on back of PC, to remove PSU)
WesleyA
26
I'm buying a new GPU, but it needs a minimum of 500W PSU. I added one to my cart, and I need to know before I buy, what is the screw head that is on the back of my computer? Can anyone tell me which screwdriver specifically I'd need?
Image: http://i62.tinypic.com/2vsg4k6.png
Can someone help me out here? I'd appreciate it. I know it's not a thumbscrew(pulling it out with my hand/unscrewing it) because I was dumb enough to try. Thanks!
Can you help me locate the specific brand on www.overstock.com? I don't deal with these types of screws much lol.
That is a combination of types. You can use either a standard "flat head" or space type screwdriver or a "torx" head screwdriver. The "torx" is most commonly found as part of a 1/4" power screwdriver bit set. If you use a "flathead" type, just make sure the actual screwdriver is a) decent "squareness" and not all rounded out, and b) same size is slightly larger than the screw, so as to not round out the inside of the screw.
ya. looks like a combo head to where you can use a flat or a torx ..
its hard to tell what you got from the store pic.s but any good hardware store or auto parts , walmart should have some
ya sas said above get one of them all in one drivers with all the exchangeable bits
Those "all in one" screw drivers - especially ones with ratchet capability are handy to have in your portable tool kit - saves a lot of space vs. bringing the big tool kit in the garage. I keep two small screwdrivers (for working on SSD drives), wire cutters and the multi-driver in my portable kit. I hate carrying around a large tool box....
Not my smartest idea. I canceled my item and ordered that lol.. thanks.
