I NEED HELP FAST PLEASE. GTX 1070 WITH 4K monitor BUT WHICH TO CHOOSE FROM THESE TWO?
Power94
407
4
4,865
Hi, i need help i need to choose my 4k monitor, i have only 2 choice.
GPU is Gigabyte GTX 1070 G1 gaming 8gb
I must to pick one of those monitors what is the best choice for me? (i don't use Free-sync tech)
1. 28" LED AOC U2879VF, 4K link: http://aoc-europe.com/en/products/u2879vf
2. 28" LED SAMSUNG LU28E590DS link: http://www.samsung.com/us/computing/monitors/uhd/samsung-uhd-28-monitor-with-high-glossy-black-finish-lu28e590ds-za/
both are Free-sync but i don't wanna and i cant use Free-sync i just use him normal
I NEED HELP I MUST KNOW THAT FAST BCS I MUST BUY FAST
THANKS FOR REPLY GUYS!
I would go with the Samsung, i have that model as well as one of their 4k tv sets and play on 1070 sli setup
Input lag is what i wanted less of and did quite a bit of research before buying a 4K TV and monitor and got samsung.
Input lag is almost non existent and compares well against higher end and more expensive options in that regard. (The TV on the other hand has a bit of of it)
Pip is pretty cool and colors are kind of amazing ( the only time i have had 1 billion was with a Sony TV prior)
Customer service is not good imo though so theres that
i play fps, open world,race etc..hard gaming and like that...no i have only that 2 choice...yea i watch movies and a little edditing ofc
This is my rig
(CPU): Intel® Core™ i7-3770 (8M Cache, 3.40 GHz)
(GPU): GIGABYTE G1 1070 GAMING 8GB
(MBO): MSI ZH77A-G43
(RAM): 16gb (4x4gb)
HyperX black 1600MHz
(HDD): 3000 GB(3.0Tb) (1x1000gb 1x2000gb)
SSD 120gb 550/500
Chieftec 750w
Scythe Mugen 3
BD-RW LG BH16NS40, 16x, SATA, crna, bulk
SCYTHE Kaze Master Flat II, KM08-BK, 5.25",
Antec GX 505
7 vents
Again, you asked for a preference. You said that you heard "AOC has faked specs" and we gave you what we thought was the best choice. It's only a recommendation. I can't speak for AOC and their warranty, but I know from expdreine (monitors, TVs, phones, etc) that Samsung has some of the best warranty teams out there. I would go with that, and protect yourself.
That depends on who you ask regarding Samsung's phone warranty. Anyone who's owned the original Note Edge got severely burned by them. AOC got the 'faked specs' view because one of their monitors failed its promised 144 hz rating for some people. Filipi's link should be viewed as well with that particular monitor in the article; and fully read. Honestly, it just comes down to who you feel more comfortable with.
yea i have only 1.2 dp https://www.links.hr/hr/kabel-delock-displayport-m-na-displayport-m-4k-2m-200600265
and hdmi https://www.links.hr/hr/kabel-delock-hdmi-a-m-na-hdmi-a-m-high-speed-sa-ethernet-4k-1-5m-200600236
https://www.links.hr/hr/kabel-delock-hdmi-a-m-na-hdmi-a-m-high-speed-sa-ethernet-4k-3m-200600237
Max_Settigns i buy 28" LED AOC U2879VF and im happy its amazing,i do my research before buying and Samsung have totally slightly lower performans then aoc...for gaming is aoc for Office work is Samsung
