I need help finding a durable usb drive that is 4gbs or under.
Flame_Runner_Fast
47
Currently at my college I am in a class where I need to use a usb drive to take an oscilloscope's waveform and save an image of that waveform on a usb drive...which has to be less than 4 GBs or else the oscilloscope will not recognize the device.
There is a problem though...I hate usb drives with detachable cover, slider, and spinning covers. Most of the time these usb drives have the necessary metal tip needed to connect the usb drive to the device...and then a slab of plastic. This design has lead me to accidentally bend the metal tip...on many different usb drives...
I want a usb drive that is durable. Like this usb drive!
https://www.amazon.com/gp/product/B005FYNT3G/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I love this one...but I don't want 2 of the same usb drives...least I mistake one of the two and then I miss out some points on a project.... Does anyone have a recommendation?
Does anyone have a good recommendation?
A label or tag on the drive will keep you from mixing them up.
There are many drives that are like what you want, but they are all larger capacity like this https://www.amazon.com/dp/B006W8U2MU/ref=twister_B01N2O8TN4?_encoding=UTF8&psc=1
These also but you may need to look around a bit to find singles instead of 10 packs https://www.amazon.com/KOOTION10pcs-Metal-Design-Shaped-Memory/dp/B00JBZS7LE/ref=sr_1_15?m=AXVIJMNVDE7L4&s=pc&ie=UTF8&qid=1487696300&sr=1-15&refinements=p_6%3AAXVIJMNVDE7L4%2Cp_n_size_browse-bin%3A1259713011%7C1259712011
