100% not a 10 bit monitor, they start at thousands.
However, if the gradients are so good to the point where it's hard to tell where the edges are, displays can be considered 10 bit, because you wouldn't notice the difference anyways.
Problem is, this (much) faster flickering, can sometimes leave artifacts behind, therefore not all displays are created equal, so the more you spend, the better quality FRC (FrameRateControl).
Because that display is marketed as having access to display 1.07 billion colors, it means that it's a 8 bit + 10 bit FRC display. They just want to use the higher number (for obvious reasons) when marketing their product.
It doesn't seem to support VESA. The images aren't clear enough, and there are no comments or reviews which can confirm it has VESA support.
Low blue light and flicker free technologies are completely useless in every sense of the word. They're nothing but marketing tricks, however it's still a valid explanation. In the end, even though they don't make it clear, all the different manufacturers are referring to CVS (ComputerVisionSyndrome), which is a real problem among users and their displays.
However, low blue light and flicker free are not and cannot reduce or remove CVS symtoms, but rather the user has to make sure the display is being used properly to minimize the effect and or symtoms of CVS. Helpful tips on top of my head:
- Increase distance from display
- Match color temperature of your room
- Lower brightness
- Blink more often
- Use matte display coatings
- Avoid a fan or strong wind blowing into your eyes
A helpful program which reduces blue light would be F.lux, or Gunnar glasses which you may have heard of, a lot of pro gamers use these for long sessions. They serve a purpose, not just a marketing gimmick.
There's no evidence yet that flicker free reduces eye strain and or headaches in any way shape or form. Studies have been made without disclosing sources, and it's just typical in the marketing world. It's unfortunate, but that's the reality we live in.
All the best!
