i need help finishing my pc build.
Jun 20, 2018
4
im in the middle of trying to build a pc. my end goal is to have a pc that can run games like GTA V and The Witcher 3 at 1440p 60+fps. i have a general idea of what parts to get, this is what i have so far https://pcpartpicker.com/list/XHDMFt . but i cant figure out what the best ram would be. im looking at the following.
https://pcpartpicker.com/product/Cf98TW/gskill-memory-f43200c16d16gvkb
https://pcpartpicker.com/product/wX7CmG/gskill-flare-x-series-16gb-2-x-8gb-ddr4-3200-memory-f4-3200c14d-16gfx
https://pcpartpicker.com/product/4n648d/gskill-tridentz-series-16gb-2-x-8gb-ddr4-3200-memory-f4-3200c16d-16gtzkw
what is the difference between all of them? what would be best for my build?
im also looking for a good case if you have any recommendations. i preferably want a black case. i really want a side glass panel so i can see in it. i was looking at the be quiet dark base pro 900, but someone told me that it is to big for my build. what do you guys think? could i get away using the pro 900 or would it just look weird and small inside with my hardware? i was also told that the dark base pro 900 has bad air flow? is that true? whats a good quiet case with good air flow? lastly will i need to buy fans to replace the stock ones in a case? if so how many should i buy?
Here is the list:
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($339.99 @ Amazon)
CPU Cooler: Corsair - H115i PRO 55.4 CFM Liquid CPU Cooler ($139.99 @ Amazon)
Motherboard: Asus - ROG MAXIMUS X HERO (WI-FI AC) ATX LGA1151 Motherboard ($259.99 @ Amazon)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory ($174.99 @ Newegg)
Storage: Samsung - 970 Evo 500GB M.2-2280 Solid State Drive ($197.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($58.87 @ OutletPC)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING OC Video Card ($834.88 @ OutletPC)
Case: Phanteks - Enthoo Luxe Tempered Glass (Black) ATX Full Tower Case ($149.99 @ Amazon)
Power Supply: Corsair - HX Platinum 750W 80+ Platinum Certified Fully-Modular ATX Power Supply ($139.99 @ Amazon)
Sound Card: Creative Labs - Sound BlasterX AE-5 Sound Card ($145.01 @ Newegg Marketplace)
Monitor: Dell - S2716DGR 27.0" 2560x1440 144Hz Monitor ($429.99 @ Best Buy)
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard ($89.99 @ Best Buy)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse ($49.99 @ B&H)
Headphones: Audio-Technica - M50x Headphones ($149.00 @ Amazon)
Other: Antlion Audio ModMic 5 Modular Attachable Boom Microphone ($69.95 @ Amazon)
Total: $3230.61
Generated by PCPartPicker 2018-06-23 05:56 EDT-0400
Better looking high quality PC for $150 more than your build(including Case + RAM) with no compromise. That extra $150 i spent on is for Sound card. If you don't need a sound-card simply remove it from the list. Sound-card will help you get your audio and sound-quality to next lvl.
