Cpu: AMD Ryzen 2700xpost all system specs here
by "blue screen" do you mean a Windows crash diagnostic screen(BSOD) or just a plain blue screen?Im not sure if it's a hardware problem or a software but I have this issue with the startup it always goes to a blue screen, it works fine after getting through the startup but once I shut it down and turn it on again it gives the blue screen
It's a bsod and when the blue screen loading gets stuck at a 100 but wont restartby "blue screen" do you mean a Windows crash diagnostic screen(BSOD) or just a plain blue screen?
and you have to reset at this screen, and then it loads? but will not load properly on a fresh boot?
