Hi all.
I am trying to repair my graphic card, its NVIDIA GTX1070 8gb FE.
There is no video output but fans are spinning.
There was a problem with electricity in my house and my monitor broke down with the GPU. I am suspecting that the power surge came threw the DVI cable.
There are no shorts to ground or 12v. I tested everything.
All voltages are present except on vmem rail (5v, 1.8v, vcore 0.7v, pex 1v)
Resistance on vmem inductor is 30ohm(not sure about this i think it shoud be higher, memory modules are made by samsung)
I removed and tested the N-channel mosfet before vmem rail inductor and it is good.
I checked the PWM controller before the N-Channel mosfet with marking 7J=YM and it seams fine(VCC=5v, VREF=2v, EN=1.8v(on RepairWiki page it says it should be arond 3v so maybe thats the problem))
I also checked the PEX PWM controler uP1728Q ( EN=1.9v, Vin=3.3v and VDD=5v)
7J=YM
https://postimg.cc/pmj0mvhZ
7J=YM
