Question I need help fixing Vegas Pro 15 Edit
dinomaster77.jw
31
I recently bought Vegas Pro 15 Edit as part of a humble bundle and I installed it but I can't seem to get it working I open it, then before it gets anywhere on the loading screen it crashes.
This is what I get
Problem Description
Application Name: VEGAS Pro
Application Version: Version 15.0 (Build 416)
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_250db833a1cd577e\igdrclneo64.dll
Fault Address: 0x00007FF991980819
Fault Offset: 0x0000000000030819
Fault Process Details
Process Path: D:\Vegas\vegas150.exe
Process Version: Version 15.0 (Build 416)
Process Description: VEGAS Pro
Process Image Date: 2018-11-19 (Mon Nov 19) 11:28:04
If you go into "device manager", and then click "Network Adapters", do you see a bunch of adapters with the name "TAP" in front of them?
That's all I've been able to find on it other than all of the fixes with AMD GPUs.
