I NEED HELP! I get a BSOD after pc booting up
Unicornio
Commendable
Jul 1, 2016
43
Hey
So I recently got a few new things for my pc - Ram,CPU and motherboard.
Now when I start up my pc, It ask's me if I want to run windows normally or start windows repair tool thingy.
When I run the fixer it never detects any problems or says that windows can't fix the problem.
When I start windows noramally it freezes on the windows logo then a BSOD appears.
I dont know what to do so please help.
You will need to reinstall your windows since you changed motherboard.
But before that you can try this, maybe it will work and you wont need to reinstall.
http://www.wintips.org/how-to-replace-motherboard-without-re-installing-windows/
Use Scenario 2 since you already changed motherboard.It might seam hard but is just quite easy if you follow steps right and dont rush.
