I need help, I have a lot of doubts about my future computer's components
XxElVonexX
19
I am interested in creating a computer buying computer components (making different combinations) with the following components:
*1st Combination:
- Processor: Intel Core i7-4770 Processor (8M cache, up to 3.90GHz)
- Graphic Card: Asus GTX 660 TI-DC20-2GDS (2GB)
- Ram: 16 GB (tell me a good ram card model quality/price)
- Hard Drive: 2 TB (tell me a good hard drive model quality/price)
- Case: Case Cooler Master K380 Front USB 3.0
- Operating System: Windows 7 64 bits Home Premium
(I know that I lack the motherboad, the refrigeration system, the power supply, etc.) (Recommed me some of them quality/price that are compatible for this combination)
*2nd Combination:
- Processor: Intel Core i7-3770 Processor (8M cache, up to 3.90GHz)
- Graphic Card: Sapphire Radeon HD 7870 GHz Edition 2GB GDDR5-Tarjeta Gráfica
*3rd Combination:
- Processor: Intel Core i5-2500 Processor (6M cache, up to 3.70 GHz)
- Graphic Card: Asus GTX 650 TI Boost-DC2OC-2GDS (GeForce GTX 650 Ti Boost)
Tell me also the budget of each of the combinations including the "missing" components (don't include the mouse, keyboard, speakers, webcam and the computer screen)
I have made any mistake about the compatibility of the components? There will be bottleneck?
Finally, I would like you to recommend me one of this computer cases :)
1. Case Cooler Master K380 Front USB 3.0
2. Sharkoon rex8 value white
It's a gamer computer, do you think that, with any of the combinations, will I be aloud to play games like GTA IV or Saint's Row 4 correctly?
Thank you!!
what is your budget for entire the build (excluding monitor, mouse and keyboard ) so we can squeeze the most out of it.also will you be overclocking? but you builds are pretty good except for gaming you only need 8GB ram and and for gaming the i5 3570k is the best value for money for gaming
Thaks for your answer!
I want to spend 900 - 975 € more or less and 100€ for a cheap monitor (27 ") And i'm not gonna overclock. I know the 'k' processors are made for the overclocking, so, for that reason, i have choose processors without the k 😀 And the other think I wanted to ask you is that if i will be aloud to play games like saint's row 4 or gta IV with 8gb Ram and the i5 3570.
And what about i5-4670? Better quality/price than 3570 and 2500?
I have some questions xD: 550 W will be suffice? And what about i5-4670 is better at quelity/price than 2500 and 3570? Im not gonna overclock. What motherboard, storage, memory, video card and power supply would you recommend me in compatibility and quality/price with the rest of the combinations? And there is much difference between the case you put me in the list and these ones?: Case Cooler Master K380 Front USB 3.0 and Sharkoon rex8 value white
550w should be fine as my friend is running a nearly identical build and hes having no problems and also although the 4670 is newer i personally recommend just getting the 3570 (non k) version if you are definitely not going to overclock also i believe it will work out cheaper to go with the 3570
if you feel unsure about the PSU then spend an extra €14 and get this http://fr.pcpartpicker.com/part/fractal-design-power-supply-fdpsuin2b750w
regarding cases if you went with a cooler master then that's fine as they are great cases as well
Yes, i gonna take the 750 W one, and as for the others combinations... What refrigeration system, motherboard and power supply should i use as for compatibility/price/quality? xD
Thaks for your answers! I think, im gonna buy a 23"-Tv (hdmi). The hdmi output has to be in the graphic card, hasn't it? So, the case has to have another output to connect the tv hdmi with the graphic card output? And, computer components cost more or less the same in all the shops? Could you recommend me one or two shops where i can find the same products than in the others but for less money? Thank youu!
the link i sent you will show you different shops if you click on the parts and also there's a HDMI port in the graphics card so you will be fine.
let me know which build/parts you decide to get and don't forget to pick best answer. thanks
Yes, i gonna pick one of yours the best answer 😀 I'm going to choose this components:
i7-3770
i5-4670
660 ti
hd 7870
650 ti boost
So i want to combine one of the processors with one of the graphic cards, wich powe supply, refrigeration and motherboard should i use with all combinations?
you cant use the same motherboard for both processors as they use different sockets but if you go with the 3770 then use the motherboard this motherboard http://fr.pcpartpicker.com/part/asrock-motherboard-z77extreme4 but for the 4670 use this motherboard http://fr.pcpartpicker.com/part/msi-motherboard-z87g45gaming, for a PSU you can get http://fr.pcpartpicker.com/part/fractal-design-power-supply-fdpsuin2b650w and you probably want to go with the 7870 and as i previously said as you arnt overclocking you can use the stock cooler that comes with the CPU
Ok... These are my last questions and you will have the best answer! 😀
1. What is better for recording, gamming and renderizing... i5-4670 , i5-4570 or FX 8350?
2. What is better for recording, renderizing and gamming... Benchmark performance using all cores or Individual core benchmark performance?
Thank you againn!!
i cant seem to find the kind of benchmarks you are looking for with the single core and multi core performance however the i5 4670 will be better for gaming but for video rendering the fx8350 will be better also i did find one benchmark that stated the 4670 is 53% better when used for for single core performance
So what of these three would you recommend me if i'm gonna recor, render and play videogames To do those three activities...
1. i7-3770
2. i5-4670
3. i5-4570
I see... So what would be better for me (gsming, renderizing, recording)... i7 3770 with Radeon HD 7870 or i5-4670 with gtx 760
And if the computer case includes 5 good fans is necessary to buy a refrigeration system?
