Question I need help instslling my new NVMe
Ramund
60
Hi! I got this nvme m.2 as a present today (SSD 1TB PCIe NVME M.2 NV1 from Kingston. Link: https://www.pcfactory.cl/producto/41850-kingston-unidad-ssd-1tb-pcie-nvme-m-2-nv1)
I have this motherboard: https://www.asus.com/Motherboards-Components/Motherboards/TUF-Gaming/TUF-X470-PLUS-GAMING/
It says it has an M. 2_1 from CPU and a M. 2_2 from PCH... Which one of those two should I use to install it?
Also... It is my first pcie ssd, is there anything I shouls know about? An option to turn on on BIOS, or anything?
Thanks! :)
kanewolf
Thanks! :)
For highest performance you want to use the one between the CPU and GPU slots. That is the one connected to the CPU.
Most people will clone their existing C: drive to the SSD to speed boot. Other hardcore gamers will choose to install their games to speed load times. With a 1TB device you may be able to do both.
Reactions: Ramund
Ramund
60
Great!
One quick question... What do you mean by the speedboost? Like... Install my new nvme drive, turn pc on... Give it format, then copy my entire (and current) C drive to the new nvme and than format?
If so... I got until that part, but then, what do I do? Like, so my pc completely recognizes the nvme drive as the new C/windows drive and not my old one?
If you meant something else, could you explain? Haha... Sorry, and thank you!
kanewolf
Great!
You don't copy. You clone. Big difference. You want the NVMe to be bootable.
I didn't say "speedboost" I said speed boot. Meaning faster boot time.
Reactions: Ramund
USAFRet
147,535
9,369
175,390
23,030
Specific steps for a successful clone operation:
Verify the actual used space on the current drive is significantly below the size of the new SSD
Download and install Macrium Reflect (or Samsung Data Migration, if a Samsung SSD)
If you are cloning from a SATA drive to PCIe/NVMe, install the relevant driver for this new NVMe/PCIe drive.
Power off
Disconnect ALL drives except the current C and the new SSD
Power up
Run the Macrium Reflect (or Samsung Data Migration)
Select ALL the partitions on the existing C drive
If you are going from a smaller drive to a larger, by default, the target partition size will be the same as the Source. You probably don't want that
You can manipulate the size of the partitions on the target (larger)drive
Click on "Cloned Partition Properties", and you can specifiy the resulting partition size, to even include the whole thing
Click the 'Clone' button
Wait until it is done
When it finishes, power off
Disconnect ALL drives except for the new SSD. This is not optional.
This is to allow the system to try to boot from ONLY the SSD
Swap the SATA cables around so that the new drive is connected to the same SATA port as the old drive
Power up, and verify the BIOS boot order
If good, continue the power up
It should boot from the new drive, just like the old drive.
Maybe reboot a time or two, just to make sure.
If it works, and it should, all is good.
Later, reconnect the old drive and wipe all partitions on it.
This will probably require the commandline diskpart function, and the clean command.
Ask questions if anything is unclear.
Ramund
60
Thanks so much!
Power off
Power up
Thank you!
Couple of questions.
First, from what you explained... Since I got a regular ssd, and the new is an nvme, I just ignore the use thw same data cables?
Also, I have many drives, a 4tb fast hard drive for steam, for example. Will the new nvme with windows recognise it and all? Or do I have to reibstall steam afterwards?
Also, on my C drive I have some programs, such as office, sony vegas, photoshop... Those will also work without an issue?
Thank you again for everything :D
USAFRet
147,535
9,369
175,390
23,030
Thanks so much!
Thank you!
Correct...ignore the cable portition.
But you MUST still physically disconnect the old drive before the first boot with the new drive.
Given a successful clone, ALL applications will still work. Incl whatever is on the other drive.
The clone is simply making a 1:1 copy on the new drive. Everything else is the same.
Reactions: Ramund
Ramund
60
Even steam that technically is installed on a different drive? :D
Ramund
60
The Steam client, or Steam games?
Either way, it should work.
The new drive is a 1:1 representation of the old drive. It should work as before, just on the larger drive.
Hi! Me again (haha) I was checking the link page from reflect... Is there s difference between reflect 7 free and reflect 7 free commercial? :)
Ramund
60
Not sure of all the differences between Home and Commercial.
I use the paid home version on my main system, Free on all the others.
I re-read everything and I vot a new question... 2 really.
You said this at somepoint: "If you are cloning from a SATA drive to PCIe/NVMe, install the relevant driver for this new NVMe/PCIe drive."
Is there a driver I should know about for my nvme? From what I've researched is pretty much plug and olay... But maybe I'm missing something?
Also, which partition is the main one? To give the extra space to that one and my Windows actually has the 1TB (aprox) of data.
That's it! Thanks again :) sorry for asking so many questions!
Ramund
60
You probably don't need a driver. That line was in there when it was probably necessary.
Don't worry about it.
Partition sizes....please show us a screencap of your Disk Management window.
Ok, thanks! :)
I had to go out now, but as soon as I get to my pc, I will upload said picture :D
USAFRet
147,535
9,369
175,390
23,030
And which drive is which?
Disk 2 is your current OS drive?
Which is the target drive?
For this clone operation, you want ONLY the source and target drives connected. All others, physical disconnection.
