Question I need help instslling my new NVMe
Ramund
60
And which drive is which?
Disk 2 is your current OS drive?
Which is the target drive?
For this clone operation, you want ONLY the source and target drives connected. All others, physical disconnection.
Yes! :) I remember that! :D All other drives will be unplugged.
Yep, Disk 2 (the one with the windows logo is the current drive. The new one I will get tomorrow, that's why it is not in the picture.
I only need to give more space to the C one? Since my one drive will be much larger, I want to take advantage of that. Or should I also give a bit more space to the other ones?
USAFRet
147,505
9,358
175,390
23,027
Yes, just the C partition.
In the Macrium client, 'Cloned partition properties'.
That will allow you to adjust the resulting size of the space on the target.
If you do not do this, the C partition on the target drive will be, atmost, 111GB.
You do not want this.
You can expand that space to include the whole remaining space on the target drive.
Ramund
60
Great! So.. you do not recommend giving some extra space to the other partitions? :)
