I need help overclocking my AMD Athlon 64 x2 5200+ CPU
Szjoks
Commendable
Feb 5, 2017
I have absolutely no experience in overclocking, so i need someone to guide me step by step trough the process.
My Specs:
-Cpu: AMD bla bla Brisbane 65nm 2.7GHz(x13.5 Multiplier)
-RAM: 2x2GB Dual-Channel DDR2 (6-6-6-18), CAS Latency 6, 3,6V
-MB: MSI MS-7309(1.11 BIOS Version)
-PSU: 400Watt, 220Volt
If you need anything else, just ask.
Thanks in advance
only way is to increase your fsb in the motherboard bios. but with such old components you will probably burn something as soon as you try (probably psu or motherboard)... be glad if it still functions and look for a new system mate, oc will not help much even if you do manage to oc it...
