i need help overclocking my amd fx 9590
Sep 19, 2018
my specs
CPU: AMD fx 9590
motherboard: gigabyte 990fxa-ud3
graphics card: Nvidia Geforce GTX 1060 3GB
cooling system: cool master- master liquid lite 120
120 GB SSD
windows 7
it freezes at 4.9 ghz i need help
To begin woth. The fx 9590 is one of the worst cpu's ever made. It gets insanely hot, consumes a stupid amount of power and is unstable at stock speeds on almost every motherboard that "supports" it. Your board is known to have a lot of issues with it so you are already off to a bad start. Even when it did run at 5ghz stable it was already being beaten by the I5's of the time at stock speeds.
Another problem a small cm master liquid is not going to keep that cpu below 60c.
So simply put. Don't oc it and get a new...
turn your pc off.
pull out the cpu and throw it as far away as you can, its that bad.
seriously, a 60 euro pentium beats that cpu in most games.
that cpu is a waste of money and you should replace it whenever you can
the answer: if you want it stable , invest in a 100+ euro cryorig a40 or nzxt kraken x62
So simply put. Don't oc it and get a new cpu+mobo+ram. You'll kill your board in no time trying to run it at stock speed so A downclock to 4.4 ghz is recommended.
Even a dirt cheap pentium nowadays matches/beats it in every task and have double the single core performance the fx has to give you some perspective.
