I need help overclocking my pc
KATZGATZ
19
Hey guys,
I want to know what i should do to my pc. (Specs will be below) So i want to know how much further i can take my GPU clock with still being in a very safe range. Also how i much i can overclock the GPUs memory clock as well. By the way im using EVGA Precision X. Also should overclock my processor? And in regard to overclocking my processor how do i do it and how much should i overclock it? If there is is anything else you think i should do to my Pc please tell.
Thanks!
EVGA GTX 770 Superclocked w/ACX cooling
Intel i7 4770k 3.5 GHz
Corsair H60 liquid cooling
Bitfenix Prodigy Case mITX
2tb drive
120gb ssd
16gb DDR3/1866MHz ADATA XPG V2
Gigabyte Z87N-WIFI mITX
750w Corsair CX750
theres no way to say for sure but your gpu should be able to hit close to 1300mhz with boost and offset if its a good overclocker or it could have problems hitting stable 1100mhz luck of the draw, so go ahead raise the offset for the gpu by about 10% and check if its stable then do it in smaller steps say by 5mz each time keep raising until it fails, then you wiwll know max clocks you can achieve on your gpu, as for the cpu check this http://youtu.be/0CHs5_TdpXE
