Thanks!!
This is his information:
Processor-Intel Core i7-2600-3.4gHz
Memory-16gb
System Type-64 bit operating system
1 SSD-Sandisk Extreme 240gb + 2 HDD's
Motherboard- Asus P8P57 Pro
Graphic Card-GTX 670 FTW
He does have an SLI slot. I thought that you needed the same card though? So I was just going to get another 670FTW.
He currently has a 1920x1080 24 inch 60hz monitor - after research it seemed that adding a second graphic card to SLI would basically be over kill with this type of monitor........SO.....I decided to upgrade to one of the two I mentioned in the post (asus or BenQ).
He plays Guild Wars 2 and wants to see improvement in FPS, no lag, smoother, etc. If this his goal what do you think the best options are? Is it true that the monitor will help to see the full effects of a second graphic card?
Thanks a lot!
