J Jay41206 Jul 9, 2020 98 0 30 Aug 23, 2020 #1 I'm putting a Sapphire RX 580 4g and a i3-9100f in my build, i didn't want to spend extra money on fans, but anything helps!
Solution Aeacus Aug 23, 2020 Well, to have good airflow, look towards mesh/grille front panel cases. Here are 4 PC cases with good airflow and within your budget, pcpp: https://pcpartpicker.com/products/compare/Yzbkcf,vYp323,P7848d,7fn8TW/ Since choosing a PC case is personal choice, pick the one you like the most.
Aeacus Titan Ambassador Mar 21, 2015 11,819 1,673 80,390 Aug 23, 2020 Solution #2 Well, to have good airflow, look towards mesh/grille front panel cases. Here are 4 PC cases with good airflow and within your budget, pcpp: https://pcpartpicker.com/products/compare/Yzbkcf,vYp323,P7848d,7fn8TW/ Since choosing a PC case is personal choice, pick the one you like the most. Upvote 0 Downvote Solution
J Jay41206 Jul 9, 2020 98 0 30 Aug 23, 2020 #3 Thank Youuu, i might go with the Antec one. Upvote 0 Downvote
Math Geek Titan Ambassador Oct 15, 2014 18,025 2,337 101,590 Aug 23, 2020 #4 i have a focus g and enjoyed building with it. there are other colors besides red. plenty of room and lots of airflow. i did add a couple fans to the back though as it nly comes with the 2 front ones. Upvote 0 Downvote
