I need help picking between two video cards for my currently unmodified emachines el1358-53
Jwb1239
6
I need help picking a video card for Gaming. Right now its a tie between the
ASUS Graphics Cards HD6570-2GD3-L- http://www.amazon.com/gp/product/B00BBNZNVG/ref=olp_pro...
And thee
ASUS 2GB Graphics Cards R7240-2GD3-L-http://www.amazon.com/ASUS-2GB-Graphics-Cards-R7240-2GD...
An answer soon would be appreciated as I have to order one within the week and i have to ship it out of the states to my country, so please help me as i wouldn't be able to return it if it didn't work or fit in my Emachines el1358-53, and THANKS IN ADVANCE.
Your rig could work with either GPU just fine, for a period of time. However, for long term use, you will really be pushing it.
Make sure NOT to overclock the new GPU with the 220 w PSU (the emachines BIOS should not let you OC the CPU/memory). Also, keep you system interior clean and your airflow as unimpeded as possible.
Like I said earlier, both GPUs will perform similarly, but I would recommend the R7.
Good luck!
You should strongly consider a PSU upgrade as well. 220w is really too little. I would recommend a solid 500-550w PSU for future growth. You really could go as little as 400w with these GPUs as well. I recommend Seasonic, Corsair, and XFX PSUs. There are several other good brands as well.
What is your budget for a PSU upgrade, along with the GPU upgrade?
Good luck!
That one looks too large for that style of case, albeit a good choice for general use.
One like this one would fit and would drive either GPU just fine. Still, OCing would not be recommended.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151115
