I need help picking the right GPU, Motherboard, and any changes caused by them.
Hayden Worlein
4
So I have been planning on building a computer for about two years and saving money and spending it and whatever but after searching and finding some parts that I like and have a nice price I'm having second thoughts.
https://www.pccasegear.com/wish_lists/589229/Okay%20this%20is%20the%20last%20one%20for%20sure
Above is the link to my current build. I will have an LG 27MP48HQ 27" which is 60Hz and 5ms response time (if that makes a difference).
I will be editing youtube videos and music and playing games such as Smite and Battlefield. I have a cat so I will need big fans and the unit will sit on my desk but I need to know about the GPU, should I keep the 1060 or go up to the 1070? I'd prefer not to spend even more money but if it can't be helped then oh well. Also, I have looked at the Motherboard and I'm just not sure? Is ASRock reliable or is there a better alternative?
Also, do I need the 750 Watt power supply? The wattage of the system is about 296 so I would not need the 750 watt, is that right?
Thanks for the help, Hayden.
Your options are limited, that is why I don't recommend shopping from one site. Shopping around gets you a better build, for your money. Chose a Z170, only because of price, here.
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($424.00 @ Shopping Express)
Motherboard: Asus Z170-P ATX LGA1151 Motherboard ($139.00 @ PLE Computers)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory ($119.00 @ Scorptec)
Storage: Crucial MX300 275GB M.2-2280 Solid State Drive ($107.00 @ IJK)
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive ($91.00 @ IJK)
Video Card: Gigabyte...
Thanks Hades, but any recommendations for the motherboard? Or for the PSU? Also what is your opinion on the GPU?
Video Card: Gigabyte GeForce GTX 1070 8GB Mini ITX OC Video Card ($589.00 @ PCCaseGear)
Case: Thermaltake Versa C21 RGB ATX Mid Tower Case ($95.00 @ Umart)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($114.00 @ Umart)
Wireless Network Adapter: Asus PCE-AC56 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter ($67.10 @ Skycomp Technology)
Total: $1745.10
Generated by PCPartPicker 2016-12-20 02:06 AEDT+1100
Hades, I did a little bit of research and the price was why I ended up on the Z170 board so thanks for that and the rest of this, I will have a look and get another opinion because it can't hurt and get back to you.
Thanks so much
