Question I need help searching an RTX 2070
FelixAFF
129
6
4,595
So i need help searching an RTX 2070 with around 204 x 128 x 42 mm Dimension so that it could fit it in my case
I found a fitting card MSI Ventus OC RTX 2070 but it got removed from the site so i cant order it and i need ur help.
So basically you need RTX 2070 with length 200mm or below.
Only single fan ITX versions will satisfy that requirement:
MSI GeForce RTX 2070 AERO ITX 8G
Gigabyte GeForce RTX™ 2070 MINI ITX 8G​
BTW - MSI GeForce RTX 2070 VENTUS 8G OC - is 226mm long. Doesn't fit your requirements.
My case can fit the Ventus OG GPU but i couldtn find it anywhere in my country, And ordering it onnlinne would take weeks.
And my case can probably take anonthher 20-30mm
