Hi,
Next year i'm going to the university to develop games.
I need one laptop to work in class with game engines, etc.
And, here is my doubt.
I have a budget of about 1100-1350€ // 1299 - 1600$.
I have been looking arround a tech page that we have here in spain, and i have found for that range of price two models that are interesitng.
First, the MSI GE63VR 7RE
CPU: Intel® Core™ i7-7700HQ (6M Cache, 2.80 GHz)
RAM: 16GB DDR4 2133MHz
STORAGE: 256GB SSD + 1TB (SATA) 7200rpm
CD READER: no
DISPLAY: 15.6" FHD (1920*1080), 120Hz wideview 94%NTSC color Anti-Glare
GPU: GTX 1060, 6GB GDDR5
Connectivity: Killer N1435 Combo (2*2 a/c)+BT4.1 M.2 type
Camera: HD type (30fps@720p)
Microphone: Yes
Battery: 6 cells 51Whr
Connections:
1x Type-C (USB3.1 Gen2 / DP / Thunderbolt™3)
4x Type-A USB3.0
1x RJ45
1x (4K @ 60Hz) HDMI
1x Mini-DisplayPort
Card Reader: 1x SD (XC/HC)
Dimensions: 380 x 249 x 17.7 mm
Weight: 2kg
Which in my country store is now for: 1365€ // 1611$
The other laptop i have found is:
MSI GL72MVR 7RFX
CPU: Kabylake i7-7700HQ+HM175 (6M Cache, up to 3.80 GHz)
RAM: 16 GB DDR4-2400, 2 Slots, Max 32GB
STORAGE: 256GB SSD +1TB (SATA) 7mm
CD READER: no
DISPLAY: 17.3" FHD (1920*1080), Anti-Glare
Connectivity:
Gigabit Ethernet
Intel 3168 Sandy Peak 1 (1x1 802.11 ac) + Bluetooth 4.2 M.2 type
Microphone: Sí
Battery: 6 cells 41Whr
Connections:
1x Mic-in
1x Headphone-out (SPDIF)
1x Type-C USB3.1 Gen2
2x Type-A USB3.0
1x Type-A USB2.0
1x RJ45
1x (4K @ 30Hz) HDMI
1x Mini-DisplayPort
Card Reader: SD (XC/HC)
Dimensions: 419 x 287 x 29~32 mm
Weight: 2.7 kg
What's is interesing about this model, is that usually is at 1349€ // 1593 , but now there's a deal of 1199€ // 1415$.
My question is.
Does the first one 150€ // 200$ more than the second one are justified?
If so, do you recomend me the first one (15,6" but 120hz) instead of the second one (17,3" 60hz) taking into account i will need to work with game engines, developer apps (thinking about small workspace).
And the last one, are you thinking of a better laptop that maybe i haven't found?
minimum with a gtx 1060, 7700, 16 ram and 256 ssd 1tb...
At home i have a 24"144hz with a gtx 1080, 6700k, 32gbram,ssd+hdd, etc,
but i will need to travell arround and move constantly.
Thank you for your attention and patience with my probably bad english, i do my best XD.
CD READER: no
Microphone: Yes
Connections:
4x Type-A USB3.0
1x RJ45
1x (4K @ 60Hz) HDMI
1x Mini-DisplayPort
Weight: 2kg
MSI GL72MVR 7RFX
CD READER: no
Connectivity:
Gigabit Ethernet
Microphone: Sí
Connections:
1x Mic-in
2x Type-A USB3.0
1x Type-A USB2.0
1x RJ45
1x (4K @ 30Hz) HDMI
1x Mini-DisplayPort
Weight: 2.7 kg
My question is.
