It has not yet been confirmed that this is a mobo problem.
i'm scared to say it's my mobo's fault because it was JUST working before installed my psu and gpu. I tried plugging in new gpu with my old rosewill 600w psu AND still it didn't. I'm getting "power". Greed leds are on, fans are good, i hear harddrive booting, my optical drive good and functioning. Cleared CMOS like 10 times, Used my memOK button( i will list specs below). I even setup my old gpu with old psu to see if that worked AND still no luck. even had ram out to boot NOThing. Case seems to be okay, power button works. I think all i've indicated my psu works. My gpu has power. double checked wire till my fingers hurt. What do you guys think or what should i do? Warranty probably won't cover it because it's been 3 years since i had this board.
cpu: amd phemon ii x6 1090t
gpu: gtx 460 (old)
mobo: M4a89gtd pro/ usb 3
psu: rosewill 600w (old)
NEW components:
gpu: gigabyte gtx 650 ti boost( literally like my old gpu)
psu: OCZ zt series 650w
I think there may be a chance i accidently shorted out my mobo. I pulled everything out while it was still powered on.
Answer back ASAP because it will decide whether i will need a new mobo. This seriously becoming a pain in the a**.
gpu: gtx 460 (old)
NEW components:
