Question I need help understanding RGB Hub
vleds123
62
Hello I have. a custom PC and i want to make it more flashy and have cool LED (fan and strips) all synchronised together.
I currently use a RaidMax 3 pack fan they come in 3 pin header fan and 3 pin header for RGB. I connect them to a hub which i also connect a strips to it it has 8 slot i think and controlled either by mobo or a remote control.
Now my mobo (Strix Z270) only has 12v 4pin RGB header so i cannot connect it to my hub.
I am looking to buy a fan cooler by ThermalTake but it uses a 3 pin RGB header. Now my question since I cannot connect it to my mobo is can i connect it to my RAIDMAX Hub and still control the CPU fan with the control along all the fan and strip. And if I purchase other fan from other brand and it uses the same header can i also connect them to my hub and they will work the same?
Is there a converter from 5V to 12V or vice versa?
Thank you for your answers!
Thread starter Similar threads Forum Replies Date
aranorde Components 2
