I Need Help Upgrading a PC! PLEASE HELP
CannonPro
Commendable
Oct 24, 2016
1st off i have lots of questions
PC Specs before posting this thread
CPU(APU) - A8 7600 Kaveri
Code Name Kaveri Max TDP 65.2 W
Package FM2+ (906)
Core Voltage 2.976 V
Bus Speed about 100 Mhz
Videocard (GPU) R7 360 2 Gigabytes of video RAM
RAM 8GB of RAM DDR3 Frequency about 1200 Mhz
Motherboard - Hewlett-Packard 2b17 1.0
Chipset AMD k15 IMC Rev . 00
Southbridge AMD a78 FCH Rev . 2.6
LPCIO ITE
PCI Express
Link Width x16 Max Support x16
Thermal take TR2 600w Power supply
I Was wondering is my motherboard even good enough to support a10 7850k? all i know is that the socket it same on both .
Can i upgrade to a GTX 960?
With that CPU (a10 7850k) and GPU (GTX 960) will there be a HUGE bottleneck?
Is the CPU worth it?
Do i need to upgrade my motherboard?
My Temperatures are Avg for the specs up above . will my pc go up in flames if i don't get a new case or fans? if i want what i want?
Sorry about grammar and spelling i speak German
Per this link it can accept the A10-7850K: http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c04293944
However, per passmark you would be going from a processor that gets a score of 5175 to one that gets a score of 5532 so you are only getting a 7% performance jump. I doubt you would notice the difference so I would say not worth it.
I don't see any reason a GTX 960 wouldn't work. And it would be a decent jump from the R7, going from 3153 to 5905.
Your PSU is good enough.
Cannot answer for bottlenecking but there are others out here that can.
