Hi everyone, so i have these two builds
and
my main issue is that i want to put 4060 ti in the second pcie slot and magewell capture card in the third but 4060 ti Height is 41mm but the third card is two pcie slots apart (40mm) will i have problem fitting the third card ? im not concerned about the heat because 4060 ti will just serve as output card for resolume and wont do any calculations.
and
