I need help with a case i want to buy!
Jim4
31
Hello guys!
I am buying a new case for my second Fury X ( it comes with a 120mm radiator) and i am wondering if a Fractal Design Define R6 can fit my 2 radiators in the front of the case(want radiators in the front side of the case)! As i read it can fit 3x 120mm fans! Fan's size has any difference from Radiator's Size? Please guys help me cuz i have no clue what to do!
I have a Fractal Design R6 and it will be able to fit 2 of the 120mm radiators in the front. Generally, the radiator size is the same size as the fan, but you will need to allow for some more clearance at the bottom of the 120mm rad where the tubing comes in. If it only supported a 240mm rad, there may be an issue of clearance, but since it will support a 360mm, there wont be an issue.
Oh, and it is a great case by the way.
I appreciate a lot that every time I need help you recommend me many things and help me solve my problems! So i will buy this case as it wont have any problems with my radiators! Thank you man i wish you all the best!
