Hello, I have an msi pro solutions Z170a sli (non plus) motherboard. Paired with an i5-6500. My question is this can A bent pin on my cpu prevent my ram from working? I have 4 Dimms of Kingston Hyper s fury 4×4gb) on the motherboard with the Ez debug Led the only thing lighting up is the Dram. Cpu isn't lit nor Vga. But I tried a single dimm in each slot, Switched out the dimm in each slot and all the same Dram is lit. Nothing else. Would the cpu be lit up if the pin was bent? I haven't taken the cpu off yet due to lack of additional thermal paste. But can use stock heatsink for the time being if needed. Please help.
