I have a Dell optiplex 7010 sff but I need to know if a 750ti evga oc will fit and if not what GPUs will
Thank you I'll try thatyou can always break out the ruler and measure how much room you have in there, and then go to the website you want to get the part from and look at the dimensions. that case from what i can see does look very very tight, im not sure if a gpu will fit in there
