I need help with building my gaming pc...
chikenzgamer12
16
ok so I'm building my first ever computer(for gaming) and I kinda need help picking out parts because I don't know a lot about computers yet(budget is $1250 USD), I want to be able to play games like GTA V smooth at like mid settings I also don't care if the parts don't have LED or look good. The parts I have are
DIYPC Solo-T1-R Black
WD Blue 1TB SATA 6Gb/s 7200 RPM 64MB Cache 3.5 inch
MSI Z370 Gaming Pro Carbon AC ATX
Intel BX80684I58600K 8th Gen Core i5-8600K Processor
AMD SILENT COOLER without LED light Socket
Ballistix Sport LT 8GB Kit (4GBx2) DDR4 2666 MT/s (PC4-21300) SR x8 DIMM 288-Pin
EVGA GeForce GTX 1050 GAMING, 2GB GDDR5
EVGA 500 W1, 80+ WHITE 500W
Please tell me if I'm missing anything that I need thx
Change your case, if you are on a budget I suggest watching https://www.youtube.com/watch?v=NdtBkN3vrpQ&
You can get a cheaper Motherboard if you'd like unless it has a feature you want
That is an AMD cooler and will not work with your CPU, get something like the Cryorig H7 or Cooler Master Hyper 212
If you can swing it I would seriously suggest getting 16GB Ram (2x8GB sticks) since more and more games are pushing that 8GB as a minimum
If you can swing it I would suggest a 1050ti over the 1050 as well.
I would get a different PSU, thats a fairly low quality in the EVGA line, on your budget a Corsair CX500M
Use a site like PCpartspicker.com to find the best deals on the parts.
PCPartPicker part list...
PCPartPicker part list: https://pcpartpicker.com/list/Tdn8Fd
Price breakdown by merchant: https://pcpartpicker.com/list/Tdn8Fd/by_merchant/
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($256.79 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($34.89 @ OutletPC)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($125.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($169.99 @ Newegg)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB SC GAMING ACX 2.0 Video Card ($199.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Total: $827.63
Generated by PCPartPicker 2018-01-24 22:29 EST-0500
chikenzgamer12
16
thanks, ill make sure to try and make those changes
chikenzgamer12
16
had no idea, thanks for the info
chikenzgamer12
16
I was working on something on the site you put earlier, can you look over my list plz
https://pcpartpicker.com/list/RMTznn
