I need help with Cable management with my corsair C70 Case and My EVGA Super Nova 850 Watt Psu.
Chaingunchris
472
The inside Of My Case Looks like S*** and its a dust magnet. please help, ill add a picture. all of the cables are stuffed at the bottom of the case which looks terrible. please help
No need to replace your case, just take some time and care to redo your wiring and you'll have a great looking machine with really good airflow.
Typically try to run all of my cables under the motherboard tray or strapped to the drive cages with zip ties. take the sides off of your case and have and try running the cables behind the M/B tray, only brining them back in where they are needed. Zip ties and hot melt glue are your friends in this endeavour.
See those grommets on the motherboard tray? Pop off the back panel, and use those to route your cables to the back, and then out to the equipment using the closest grommet. That will keep the rat's nest out of sight, and while you're rerouting, you can neaten up the bundle and secure it down with ratbelts to make sure it remains flat and nothing gets pinched.
you mean the big gourmets in the case leading to the back?
Then tape it down low on the mobo tray, less fall less shock. But with no moving parts, an SSD can handle a much harder bang than a spinning drive.
If you're worried about the tape not sticking, head to an auto parts shop and buy some 3M trim tape, this is what the use to stick badges and visors on to cars with. Ask the guys at the counter, he'll know what you're looking for.
ok, well give me some stuff to do now, i don't have the time now but ill get to it this saturday which for me is like in 2 days
like you saw the picture of my case now, right? xD. is it realy possible to fix that mess?
Did you not look at my C70 case and my power supply is not modular so I have all the cables to hide.
Do you a couple of Google PC cable management youtube searches and watch a few videos.
Oh, ok
that cant be a non modular psu : /, I also have been watching some youtube videos about it. its not that hard. i Can do it 😀
Sure it is.
Every cable coming out of the power supply should be routed through the grommet right there by it, to the backside of the case.
If you think you're going to have trouble remembering where to plug everything in -- put little tags on each cable to label where it was connected.
Thanks for the help everybody this is why I love toms hardware 😛
