Question I need help with connecting front panel connectors to older mbo
May 11, 2021
Hi, so i switching old ASUS P6T SE motherboard with Xeon CPU to new PC case and i need help with front panel connectors.
Here is the manual of MBO link
i have: two pin power sw, two pin reset sw, one pin power led -, one pin power led+, and two pin hdd led.
link1 link2
link1 are audio connectors,
not for case front I\O panel.
link2 is the front panel header.
and it seems to be pretty well defined and matching what you have for case cables.
just match up the cables with their proper connector and make sure they are oriented correctly.
what exactly is your problem?
