Hello gus just finished my build and I want to learn some info about drivers when in install them then what do I do how do I apply them
Drivers help run programs and come with the essential parts of the computer usually on a CD. Your graphics drivers should all be on the CD your GPU came with and any motherboard drivers will be on the manufacturers website or another CD. When installing them, it's just like installing a program. Make sure to restart your PC after installing drivers
you just need to install them and that's it. And if you want to tweak some settings then you can simply right click on the desktop and open the control panel.
