So I built a gaming computer for myself but I have not even got it to bios it keeps have long a boot loop and take every part out 1 by 1 and got a new motherboard I not now want the problem is
Need full system specs.
For theWhat i3 CPU? Need a model.
And what is the make and model of that PSU specifically?
So I need to download something on the cpuFirst be sure that your monitor is plugged into the 1050ti video output and not the motherboards.
Second you need to have BIOS version F2 installed in order for that CPU to work. If thats the case without an already compatible CPU installed you cant update the BIOS. You will either need to borrow or take to a PC Repai shop in order for this to be done,
https://www.gigabyte.com/us/Motherboard/B365M-DS3H-rev-10/support#support-cpu
Is there anything to buy without borrow also I took the cpu and graphic card out and it still having a boot loop Chould it be the power supplyPossibly your BIOS is not up to date. Since your CPU doesn't have integrated graphics it's hard to rule out if you have a faulty graphics card. You would need to borrow a card from somone.
As I said though it's most likely your BIOS is not updated to support the 9100F. You will need to either borrow an already compatible CPU and install it. Or take it to a PC repair shop and pay them to do it.
Also I don’t now if this help but my motherboard flash OrangeIs there anything to buy without borrow also I took the cpu and graphic card out and it still having a boot loop Chould it be the power supply
Okay thank you I say how it goes when I go to a shopNo. Listen you seem like this is a bit over your technical knowledge so I would strongly suggest looking around your area for a reputable repair shop and pay them to can get you up and running.
The motherboard light from what I can find is simply a power indicator light, however if it is flashing then it could mean you don't have the PSU hooked up correctly. I strongly recommend you watch a how to video as well as consult your motherboard manual in hooking up everything.
By any chance you Chould recommend a shop near 46544 sip code or in IndianaOkay thank you I say how it goes when I go to a shop
