I need help people.
My system contains the following:
i7 6700k Overclocked to 4,6 ghz
Corsair H80i Closed loop Water cooler
MSI Gtx 1080 ti Gaming x GPU
32 GB DDR4 Ram 3200mhz
2x Samsung Evo 850 SSD 500 GB
Seagate Firecuda 2TB SSHD
Asus Z170 Pro Gaming Motherboard
Corsair CX750M PSU
Playing on 1920x1080 144hz
I searched around the other threads and i can't seem to find JUST what i need answered.
So when i game, this system is ofcourse pretty sick, but it COULD be sicker, IF the USAGE on both CPU and GPU were higher.
It's only in battlefield 1 that the usage is high on both the CPU and GPU, with 99-100% usage on GPU, and 80-90% usage on CPU (i use msi afterburner to check) I get anywhere from 144-160 FPS with a resolution scale set ingame to 130%. I get 70-80 when turning it all the way to max 200% resolution scale. It's only in this game it seems to use my systems specs properly.....
When i play most other games:
1. Heroes of newerth= 25-30% GPU usage, 20-30% CPU usage, 90-125 FPS
2. Squad = 60-70% GPU usage, 60-80% CPU usage, 100-150 FPS
3. Rising storm 2: Vietnam = 50-60% GPU usage, 60-70% CPU usage. 90-130 FPS
I need to get an explanation for this, because i think there is something i might be missing. One would think that the hardware could get me atleast 144 FPS, since i play on that fairly low resolution but with 144 hz. I tried to go to control panel in Nvidia and set the power management to " High performance" instead of "Adaptive performance", but this dident help i think.
What is the cause for this?
Poor optimization?
Bottleneck?
What is it?
Corsair CX750M PSU
Poor optimization?
Bottleneck?
What is it?
