I need help with graphics cards
Chrisamato
have a AMD radeon rx 480 and was wondering why when I connect two monitors and try to play gta 5 or bo3 in extended screen it only plays in one. Do I need a second 480? Thanks
Extended screen just means they are two different monitors where you can slide your mouse from one to another, games can only be played on one monitor.
you have an amd so there is something called catalyst controller or radeon setting just right click on the desktop and the first one should be about amd and from there you have a tab for eyefinity which can make both run as one desktop resoultin into game playing extnded to both desktops here are some links: https://www.youtube.com/watch?v=8g-xB7tzzig
it than depends on what you have to click if you have the catalyst controller or crimson which means if you updated or not
if you dont have any of this go download the correct drivers from amd website directly
Games can definitely be played on two monitors specialy amd gpus check my answer for how to do it
Oh sorry, I'm not familiar with any of AMD's options because I've only run Nividia. :)
